Internet Radio / Radio Paradise directory not showing
If you are experiencing issues with your RADIO within your InnuOS, such as not being able to see any options in the RADIO section, note that you must have your DAC properly connected and turned ON in order for your RADIO options to appear and work.
No radio available sample – when DAC is NOT connected (or ON) sample image
  • Make sure your DAC is powered ON
  • Check your cable connection between your Innuos and your DAC
If your RADIO Paradise options are not showing, make sure your DAC is properly connected and powered ON.
DAC connected and powered ON sample image
Note that you may be required to refresh your browser (if using your my.innuos.com) or restart your Innuos Sense APP to see the results
Dislike 2
