USB Latency Settings
You’ll notice a parameter in the Audio Settings menu in Sense for “USB Latency”.
You can access Audio Settings by going to System > Settings > Audio
By default, this parameter is set to ‘Normal’ to provide better compatiblity with DACs. However, setting it to ‘Low’ can enhance sound quality in your system. We recommend switching to ‘Low’ and testing performance for yourself and compare the two options. If you encounter any issues, such as no sound or audible pops, simply revert the setting back to ‘Normal’.
