The Master Reclocker is designed to improve the quality of digital audio by regenerating the USB audio stream before it reaches the DAC. It provides a single, ultra-precise clock reference for digital communication, reducing phase noise and delivering a cleaner, more accurately timed signal. It operates in an electrically quiet environment that’s isolated from the processing, storage and operating system activity found inside a music server or streamer, preserving signal integrity right up to the DAC.
As standard the NazaréFLOW is a full USB Reclocker with a reclocked USB output on board, but its modular design means that it also benefits from dedicated output modules. These are custom-designed and purpose built for selected high-end DACs, tailored specifically to the protocols used in proprietary connections that include:
– MSB ProISL
– CH Precision CH Link
– EMM Labs Optilink
*Additional boards in development
The DAC’s own audio clocks remain responsible for conversion while the Master Reclocker controls the communication timing, ensuring every stage is optimised. Even when using a standard USB DAC, the built-in reclocked USB output still delivers the benefits of a cleaner, lower-noise signal path.
To integrate the Master Reclocker into a hi-fi system, simply connect your music server or streamer to the NazaréFLOW via USB – this would be the PreciseUSB port if using the NAZARÉ itself.
Then connect the NazaréFLOW to your DAC using either a dedicated FLOW module or the built-in reclocked USB output. In effect, the NazaréFLOW sits between the source and DAC, acting as a precision timing and signal regeneration stage that optimises the digital connection.
To maintain the best consistent performance, we suggest leaving the NazaréFLOW powered on.
From a powered-down state, please note that you should allow two to three days for the FLOW to reach optimal performance.
