How to use Qobuz
QOBUZ is a third-party paid streaming service. You will need to create your account prior to adding it to your Innuos system. If you have not already, go to qobuz.com, create your account and choose your plan.
How to login to Qobuz in Sense
1. To login to Qobuz, please go to System > Settings > Streaming services.
2. Here you can now login to Qobuz via multiple methods such as directly with your email/password or integration with Google, Apple or Facebook.
Once logged in, you will notice the system tasks icon appear in the bottom right-hand side of Sense as your system will immediately begin importing your favourite Qobuz tracks and albums into your Sense music library.
3. Once your system has finished updating your library, you will be able to see your Qobuz favourites integrated within your existing library directly from the Music tab in Sense.
You can easily tell apart music from Qobuz and your local library, as albums from Qobuz display a small Qobuz logo in the bottom right corner of the album art, as shown below
You’re all done, that was simple!
You can easily tell apart music from Qobuz and your local library, as albums from Qobuz display a small Qobuz logo in the bottom right corner of the album art, as shown below.
How to use Qobuz in Sense
You can find music in Qobuz in multiple different ways.
1. Your Qobuz favourites will now be filtered into your main Music library, so you can simply go to the Music Tab in Sense and manually find your desired music via one of the respective categories such as Artists, Album, Playlists to name a few.
2. You can now use the Sense Search function to discover new music on Qobuz, and if you prefer, you can filter results to show only Qobuz content rather than what’s already in your library. By default, Search will look across your entire library, including locally stored files and any connected streaming services. To refine your search, simply select ALL next to the search field and choose from the drop-down menu to focus on local files or a specific streaming service.
3. If you want to access Qobuz specific features such as Qobuz Mixes, you can head to the Qobuz tile via the Music Tab in the Streaming Services section. Select Qobuz and it will bring you to the Qobuz homepage.
Here you can see what new music has been added to Qobuz as well as various other features such as curated playlists and recommended audiophile albums.
