How to use Idagio
How to login to Idagio in Sense
1. To login to Idagio, please open the Sense app and from the System tab go to > Settings > Streaming services and select the Login button under Deezer.
2. Here you can now login to Idagio. A pop up browser will appear for you to enter your Email and Password to login.
3. Once logged in, you can head to the Music tab, and in the Streaming Services section you will now notice a dedicated Idagio Tile. You can access your Idagio library here.
4. Enter the Idagio tile and you find various categories to find the music you’re after, beyond simply looking at your own personal Collection, you can also discover music through several features: curated playlists created by IDAGIO staff, artists, and partners; the Moods Player, which helps you find music for specific moods such as Concentration or Meditative Music; and personalised recommendations based on your listening habits.
Please note that the current Idagio implementation does not fully integrate into the unified Sense library in the same way as Qobuz or TIDAL. This means you cannot mix Idagio playlists with other services or local sources.
