How to use HighResAudio
How to login to HighResAudio in Sense
1. To login to Idagio, please open the Sense app and from the System tab go to > Settings > Streaming services and select the Login button under Deezer.
2. Here you can now login to HighResAudio. A pop up browser will appear for you to enter your Email and Password to login.
3. Once logged in, you can head to the Music tab, and in the Streaming Services section you will now notice a dedicated HighResAudio Tile. You can access your HighResAudio library here.
4. Enter the HighResAudio tile and you find various categories to find the music you’re after, beyond simply looking at your own personal library via the ‘My Music’ category, you can also discover music through other available categories too!
Please note that the current HighResAudio implementation does not fully integrate into the unified Sense library in the same way as Qobuz or TIDAL. This means you cannot mix HighResAudio playlists with other services or local sources.
