How to use Deezer
Deezer is a third-party paid streaming service. You will need to create your account prior to adding it to your Innuos system. If you have not already, go to deezer.com, create your account and choose your plan.
How to login to Deezer in Sense
1. To login to Deezer, please open the Sense app and from the System tab go to > Settings > Streaming services and select the Login button under Deezer.
2. Here you can now login to Deezer via multiple methods such as directly with your email & password or integration with Google, Apple or Facebook.
3. Once logged in, you can head to the Music tab, and in the Streaming Services section you will now notice a dedicated Deezer Tile. You can access your Deezer library here.
As illustrated, when you enter the Deezer tile you will find access to Deezer’s Flow function, as well as Charts, New Releases, Mixes, Genres, and your own collection of saved favourites under My Library.
The ‘My Library’ section will have everything you’ve marked as a favourite in Deezer. The integration updates instantly in real time, so there is no need to synchronise like you do with TIDAL or Qobuz. Any music you save or add as a favourite while browsing Deezer content in Sense will also appear in your Deezer app, and the same works the other way round. This includes tracks added to Deezer-based playlists.
Please note that the current Deezer implementation does not fully integrate into the unified Sense library in the same way as Qobuz or Tidal. This means you cannot mix Deezer playlists with other services or local sources.
