Which USB optical drive do you recommend for CD Ripping on STREAM and Next-Gen?
Generally, the majority of optical drives should work without issue.
The ZenDrive series from Asus are widely available with a good balance of value, design and performance.
You can get feedback from us and from our community on which USB CD Rippers have worked well with their Innuos systems. This should help you decide which option is best for you.
USB CD Rippers
