System Tab
The System Tab in Sense is the home of multiple key features, as well as important system information.
System Information
System Name – Displays your system’s name. You can rename the system by selecting the pencil icon to edit.
Innuos Model – Below the system name is the model of your Innuos system.
Serial Number – The 13-digit serial number for your system.
Storage – Shows the total capacity of your storage, how much is currently used and how much remains available (only present if a storage drive is fitted).
Network Information – This tile indicates the network connection status and displays the system’s IP address and MAC address.
System Utilities
If your system has integrated storage, all four system utilities will be visible. Systems without storage will show only Backup and Settings.
Disc Ripper – This tile takes you to the Disc Ripper settings page, here you can adjust various settings related to ripping your CD collection.
Import – The Import page allows you to bring music files into your system, where you can choose to import from USB drive, NAS drive, or Auto Import folder [RELATED ARTICLE].
Backup – Takes you to the backup options page, where you can choose between USB and NAS methods to back up your music library.
Settings – Opens the main settings section where you can find important options for your system including audio settings, software updates, system modes, streaming service accounts and more.
