SenseUPnP – Naim Users troubleshooting
For users running modern Naim Audio streamers supported by our Naim SenseUPnP profile, if you encounter playback issues specifically relating to subsequent tracks being skipped, please check the following LMS setting and adjust it accordingly.
Could you please check the LMS setting on your system and confirm whether it is currently set to Persistent or HTTPS Cache mode.
If it is currently set to Persistent, please change it to HTTPS Cache mode instead, save the setting, reboot the system, and then test playback again afterwards.
To access LMS, you need to use a web browser so this is more easily done on your PC/Mac.
On your browser, edit the URL bar and add “:9000/default/settings/index.html” to the IP address for your system so it looks like “192.168.1.100:9000/default/settings/index.html” for example.
Navigate to “Advanced”, and select “Network” from the drop down menu, and adjust the setting as described above.
