The Home tab is the main landing page of Sense app, designed to give you quick access to your favourite music and easily begin playing content from your library
Widgets
A variety of widgets are used as shortcuts to your favourite music. These widgets include:
- Presets
- Favourite Mixes
- New Music
- Most Played Playlists
- Favourite Playlists
- Last Played Tracks
- Favourite Radio Stations
- Favourite Podcasts
Editing The Layout
Using the Edit icon at the top right of the screen, you can rearrange the order of widgets or remove any you do not wish to use.
System Events
The Home tab also has access to the System Events history, where notifications will be posted about the status of imports, backups, available software updates and more. This page can only be accessed on the Home Tab via the Bell icon in the top right corner of the page.
