Output Modules: What You Need to Know
We now offer a range of Output Modules available to use across STREAM Series & ZEN/ZENith Next-Gen systems. These Output Modules are available upon request with a new system and can also be installed into existing systems by your dealer.
All Innuos systems come standard with a USB output, ensuring you have access to this feature even if you order a system without an output module.
All output modules must be fit by an official Innuos dealer.
The new Output Module options are as follows:
  • StandardDAC
  • PerformanceDAC
  • PhoenixDac*
  • SPDIF Board
  • PhoenixUSB Board
  • PhoenixI2S Board**
* PhoenixDAC is ONLY available on STREAM3 systems.
** PhoenixI2S is ONLY available on STREAM3 & ZEN/ZENith Next Gen systems.
Standard Dac Board:
Add RCA analogue output, plus optical and coaxial SPDIF outputs.
Supports PCM up to 24bit/192KHz.
Available on:
STREAM1
StandardDAC
PerformanceDAC Board:
Latest AKM DAC chip and high-quality TCXO clocks.
Support PCM up to 32bit/768KHz, Native DSD up to DSD512.
Independent power supplies for digital and analogue stages .
High-Quality Gold-plated RCA Connectors.
Available on:
STREAM1
STREAM3
PerformanceDAC
PhoenixDac:
Dual Mono AKM DAC Chips with OCXO Clock plus FemtoClocks for Audio.
Support PCM up to 32bit/768KHz and Native DSD.
Independent Power Supply for Digital and Analogue Stages.
High-Quality Gold-plated RCA and XLR Connectors.
Available on:
STREAM3
PhoenixDAC
SPDIF Board:
Provide a superior SPDIF Coaxial, Optical and AES outputs for your DAC.
Optimised power supply for ultra-low noise.
High-Quality Gold-plated Connectors.
Available on:
STREAM1
STREAM3
ZEN Next-Gen
ZENith Next-Gen
PhoenixUSB Board:
Regenerated and Reclocked USB signal to your Class 2 USB DAC, greatly increasing sound quality.
High-precision 3ppb 24MHz OCXO clock for greatly improved timing and signal integrity
Ultra-low noise LT3045 linear regulators for each independent voltage, no switching regulators on main USB chip.
Provides a pristine 5V line for the USB connection on your DAC.
Available on:
STREAM1
STREAM3
ZEN Next-Gen
ZENith Next-Gen
PhoenixI2S Board:
Bypass conversion stages with a direct connection straight to your DAC chip.
3ppb 24Mhz main clock, with two premium FemtoClocks.
HDMI connector with 8 pin-configurations.
Ensure maximum audio resolution compatibility up to DSD1024.
Available on:
STREAM3
ZEN Next-Gen
ZENith Next-Gen
