innuOS 1.4.7 – Released 27/01/2021
This release further upgrades the base innuOS libraries in preparation for innuOS 2.0. Additionally upgrades LMS to version 8.2 in order to resolve current TIDAL integration requirements. Please note this is a long update that can take up to 30 minutes depending on the speed of your Internet connection.
Due to the upgrade of the network libraries, the system will change the IP address during the update which will cause the UI to lose connection and keep indefinitely in the “Updating” screen. To resolve, please go back to my.innuos.com and navigate again to Settings > System Update. If the status is still updating then system is still running the update – allow 5 minutes and then repeat this procedure. If there is a window indicating system needs to reboot then the update is complete and please click the reboot option to reboot the system. Please do not turn off your system until the update is complete.
Fixes
  • Fixes TIDAL integration with innuOS
  • Updated Logitech Media Server to version 8.2
