I2S Output Module Settings
Please review the table below alongside your DAC’s I2S settings to ensure you select the correct dial on the rear of your Innuos system.
For units pre-fitted with the PhoenixI2S Lite module, the default setting is Profile 6 (highlighted in green in the table), as this is the most commonly used standard for I2S DACs.
